10.5kw shower wired in 10mm twin n earth on a 40A breaker a problem | Page 3 | on ElectriciansForums
Discuss 10.5kw shower wired in 10mm twin n earth on a 40A breaker a problem in the UK Electrical Forum area at ElectriciansForums.net
G
giddash
Hi there,
I did wired 10.5kw shower with a 10mm cable on a 40A breaker for an old lady's bathroom.she recently got a builder in to do some tiling work and this guy thinks the wiring is wrong and that i should have use 45A breaker else the house will catch fire.I don't think his is right as there no way this could happen as I did test the breaker and it tripped in less than 5s but tought i should post this any way.
i see downrating of MCB's quite alot, wouldn't even code it tbh. i wouldn't design it like that either, whenever i find it it's been like that for years and you know the old saying, if it aint broke don't fix it. if i remember correctly a modern MCB will trip at 1.45 times the rated current. so thats 58A for a 40A breaker, i think it will be alright
Testing an mcb is like seeing how long your tent would cope for in a Hurricane,
Apply a 150 mph wind and the tent gets destroyed after staying up for a second
The tent may have passed the test, but its not a lot of good for sleeping under again lol
And these shower ratings are sometimes a bit of an exaggeration
im considering putting my 10.5kw shower on a 40a rcbo, 1 because they dont do bigger in crabtree and 2 because i dont want to buy a seperate shower unit of 63a rcd with 50a mcb....if it trips then ill have to change it but if anything its safer.......
- - - Updated - - -
davewdave;748232]im considering putting my 10.5kw shower on a 40a rcbo, 1 because they dont do bigger in crabtree and 2 because i dont want to buy a seperate shower unit of 63a rcd with 50a mcb....if it trips then ill have to change it but if anything its safer.......
I can't understand why anyone would even consider installing a 10.5 KW shower, let alone actually installing one!! lol!!
its a modern phenomena eng called `my showers bigger than yours` at the neighbours...
a bit like the `chicken brick` that used to be sold by habitat back in the late 70s early 80s...so all the street would come round to admire it...a stoneware pot you cooked a chicken in...
anyway...the point is some feel the need to have the best kitchen, biggest shower,sparklyest bathroom etc...
these people need patience and understanding.....
They need a good kickin Glen......My wife is exactly the same, she has to have better than my cousins missus.....She needs a good kickin aswell!!lol
Reply to 10.5kw shower wired in 10mm twin n earth on a 40A breaker a problem in the UK Electrical Forum area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
