E
edrobbo8
I am trying to find out who the manufacturer of this fitting is? They are on a portable generator floodlight set.
Have a feeling it is Thorn, but nothing obvious on the units. Anyone seen them before? I need a replacement glass lens!
As spartykus said, they're practitioners In light, whatever that means! Bit of a pain. Spartykus Does the glass of the 250w fitting you have in the stores measure 400mm wide by 445mm high?! May be worth buying a cheapo fitting and pinching the glass from it. And yes it is mega bright, temporary sports floodlighting.
I can't see a 400mm X 445mm bit of heat proof glass costing £250, that amounts to over half the cost of a new fitting!! Check around, that place you tried, probably didn't have any in stock, and wanted you to pay for a far bigger sheet for his stock!! lol!!
Hello
no, its 290 x 410 (approx, thats the outer casing dimensions). The one Ive got is " NVC lighting technology".
1000W Metal Halide Floodlight replacement lens
edrobbo8,
Guest55,
