10mm T&E for Consumer unit supply | on ElectriciansForums
Discuss 10mm T&E for Consumer unit supply in the UK Electrical Forum area at ElectriciansForums.net
Sav
Morning everyone,
Hope your all well.
Just a a quick question. We have been asked to quote for a HMO conversion, in a domestic property. So basically, the developer buys these houses and makes rooms out if them.
Leach room is basic, small ensuite shower ( not electric ), lights and a few sockets. There is a communal kitchen and each room is supplied by its own consumer unit.
There are 2 circuits, lights and sockets.
What I'm asking is, the consumer units are fed via 10mm T&E that go down to 60A isolators, which in turn go into a big Henley block.
There are about 5 rooms, so five isolators.
I would have thought that the consumer units for each room , from the isolators had have 16mm earth ?
Obviously things like communal smokes and fire alarm system etc are fed from landlord board.
The supply is a TN-S single phase
regards,
sav
Ok. The set up his current electrician has is as follows
single phase TNS 100A BS1361. Tails into single meter.
From there into Henley blocks using 25mm tails.
From Henley blocks, 25mm tails into Mk60A isolator.
From isolator 10mm T&E ( presume buried in wall & under floor etc into consumer unit.
Consumer unit has 30ma RCD main switch and 2 circuits. Lights and sockets.
I also would have though swa from isolator into consumer unit.
But I would use 16mm ??
bonding as far as I could see is main gas and water in 10mm. I couldn't see an earth from the metal isolators to the MET though. Also couldn't see any supplementary bonding in the rooms. That's why the alarm bells rang in the head.
But I don't think 10mm T&E is the way to go ?
Sav
Morning everyone,
Hope your all well.
regards,
sav
cant see myself renting off this fella though....
this keeps cropping up does this.
inappropriate cable type for the proposed feeders
as Murdoch has quite rightly pointed out the way forward here is SWAs with bottom end additional protection for finals...
63A cut out for a DB supply with only a socket and light circuit?? What's the max demand of each unit, 20A? I'd be looking at maybe a 20A MCB in a DB at the origin then on to a local two way RCD DB fed via SWA sized accordingly with a 16A for the sockets and a 3A for the lights. Will each unit be seperately metered and if so, will that be a suppliers meter or a private landlords meter?
As others have said there is far too much we don't know to provide accurate advice so I'm only speculating, one thing is for sure though and that is this installation needs some proper thought out design. Slinging in 63A switch fuses and T+E submains just doesn't cut it I'm afraid.
16mm for 1 sockets & 1 lights circuit ?
do me a favour , the existing 10mm is already hideously over rated as it is for what will unlikely be more than 20A per unit after diversity
4 or 6mm t&e subs in pvc trunking to each bedsit is the sort of cost savy design you should be considering.
a 20mcb at the start wilpl trip at same time as 16 if a fault occurs
Some partial discrimination between the upstream ocpd and the final circuits imo would be a good thing here, especially if the incomers are some distance from the flats.
And in this instance an HRC fuse (Switch fuse) to MCB in CU, would be better than MCB to MCB.
Infact, if your not worried about OCPD discimination and the posibility of the upstream device (MCB) operating under fault conditions on a flats final circuit, why worry about a front end RCD being installed?
The OP could go for 45A HRC fuses then, I still think it's overkill though, especially cost wise. How many short circuit faults are we anticipating will occur?
Front end RCDs are bad for a whole host of reasons as they trip under many different conditions.
Reply to 10mm T&E for Consumer unit supply in the UK Electrical Forum area at ElectriciansForums.net
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
Recommended Sponsor News
Hi everyone,
