16a socket | Page 5 | on ElectriciansForums
Guest viewing is limited
Discuss 16a socket in the UK Electrical Forum area at ElectriciansForums.net
E
elementps
Hi all, hopefully just a quick one.
Been asked to install a 16a commando socket in commercial premises for table saw.
It will be on a dedicated 20A radial cct.
Although the appliance is rated at 15A, it does state to allow for currents of up to 18A for start-up.
So my question is relating to the commando socket, would a 16A socket be considered suitable, will it handle the 18A short term current?
Or should I be specifying a 32A commando socket?
Opinions please?
If the appliance draws more than 16amp it shouldn't have a 16amp plug fitted.
How about if you use one of these? Never actually seen one, but I assume they're not fused?
[ElectriciansForums.net] 16a socket
Edit: And what if you use that on the end of a 16A extension lead?
Well, thanks all for your posts, didnt really consider using a 16A breaker. In my understanding the MCB is there to protect the cable, as a circuit protective device.
And as long as the cable is adequately sized then no probs.
For the person who suggested rotary isolator and fixed wiring; they actually have 2 machines they want in use, however only one socket, only one machine will be used at a time. Otherwise this was my plan.
Final opinions now: 1 x 16A socket on 16A MCB or 20a???
Reply to 16a socket in the UK Electrical Forum area at ElectriciansForums.net
Stick the socket in a large plastic wall box with hinge and padlock. Give customer letter with key...
