Discuss 16mm meter tails, long run in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The initial question is regards meter tails and excessive length
A later post then says there is a Kmf which feeds the dist board at the meter position
There seems to be a bit of a mixing of your lager and Beer bottles somewhere along the lines
Reply to 16mm meter tails, long run in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bloody Hell! Wishing you a speedy recovery and hope (if) anyone else involved is ok.
Ivan
Normally you'd install either a fuse-switch or a switchfuse at the incoming supply position rather than a DB, this gives you some hope of...
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
