I disagree. Nothing to do with technical terms, it's just really badly put together. The question (or statement if you like) has 4 answers, 3 of which are correct: 1,2 and 4.Hi guys,
Looking at this question in detail, I would like to add my two pennyworth. I think the question was sound and correct. It is peoples mis understanding of technical terms that leads to questions being interpreted as not being correct. In part two (definitions) of the regulations it clearly states what an RCBO is designed to do. However could I deflect your attention to the table A53.1 on page 188 of the regs book. There you will see that an RCBO has functions to protect against:
Overload, Short circuits and Residual Currents
whereas an RCD (as one of the RCCB family) only protects against Residual Currents
and Residual currents are again described in Definitions part 2.
Therefore both protect against Residual Currents, but of the two only the RCBO protects against short circuits
Enjoy the Bank Holiday, I need to get out more.
Regards
JohnC
That is also a big dodgy.Another question I'd like to take issue with! Regulation 411.3.2.3 clearly states a maximum of 5 seconds. The question clearly asks for the 'maximum' What am I missing?
I chose 5 seconds, but the 'correct' answer is 0.4ms apparently...That is also a big dodgy.
For a TN supply it is 5s sub-main or 0.4s for a final circuit. But the one you ticked was 0.4ms which is not feasible for a 50Hz supply!
Well they have a mistake in the list!I chose 5 seconds, but the 'correct' answer is 0.4ms apparently...
Reply to the thread, titled "18th edition exam question.." which is posted in UK Electrical Forum on Electricians Forums.
