1st fix time for timber frame | on ElectriciansForums
Discuss 1st fix time for timber frame in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Evening all
Have many of you worked with timber frame buildings? Im pricing 9 houses which are all timber frame and have easy joist so no drilling of joists
All houses are 4 bedroom with TV and DATA points in each room, downlights downstairs and a garage with a light and socket
How long would you allow to first and second fix? I feel i work fast....
I would price like i do all jobs now, per point regardless of whether its brick or timber etc
If you want the job then knock a fiver off per point.
Not worth doing for day rate and cost of materials.....you are here to make a living :)
Hi,the size,spec,type of equipement,how many and who are the other trades,working at the same time.....
Going to be a wild stab to give pricing,which will alter also,if you are on your own.
I may offer to show my undressed parts....if you do not have to do any drilling ?
Pendants everywhere apart from bathroom, en-suite, kitchen and utility which are downlights. 3 story house...bedroom and en-suite top floor, 3 bedrooms and bathroom middle floor. kitchen, living room, utility And WC ground floor. Sat and cat 5 to all tv points, door bell and outside socket.
Did you have to fit your own noggins?
Reply to 1st fix time for timber frame in the UK Electrical Forum area at ElectriciansForums.net
After fitting out the first room of downlights.... i expect him to get a bit speedier at fitting them There is so many unknowns to price at this...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
