2 core cable.. | Page 4 | on ElectriciansForums
Discuss 2 core cable.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you consider this thread pointless, why did you waste your valuable time replying to it?
Negativity is not required in this discussion. Thanks anyway.
Nothing negative about that post at all... It is what it is, a pointless discussion. In the real world it wouldn't matter a jot if you run a flexible cable to a class11 fitting/appliance that included a CPC or not!!
Maybe a little commonsense would have resolved everything before the OP's thread was even posted!! But that is in very short supply in this day and age!! Now you need to see every little detail in black and white, and when you can't find it, panic sets in!!
Reply to 2 core cable.. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What readings were you expecting for the cable prior to testing? What is the make of the protective device? Is there any previous paperwork [test...
A problem putting multiple cores into a ferrule is when you need to do testing or fault finding. You can't just drop the ends out of the terminal...
