What is the switch currently feeding? because this is what you want to be looking at, the switch is just a switch.
EDIT: BTW didn't mean any offence thought you were a member of the public! Turns out you could teach me a thing or two (or three)
EDIT VOL II: just re read and I think I know what you mean. Without thinking about it too much it appears to me that youll need to run more cables. You'll have some kind of 'rose' effort going on in the existing fitting - switch, neutral and loop.You'l have to take a neutral and line (loop) to another arrangement, then take a switch wire from loop down to the (new, additional) switch, then back up to the 'switch' part of the arrangement (i.e. the bit attached to the line side of the appliance). Is that what you were after?
ecotech, on a 2 way switch you have one perm feed, coming from the loop terminal on a normal ceiling rose, and you have a switch live which goes to the live terminal in the ceiling rose. You then have 2 or 3 (depending on installation method) live cores betwwen the switches.
can you not just run a cable from the nearest ceiling rose. Then you have a loop and a neutral and earth. run the core from the loop down to your switch, the other core goes form the other end of the switch to your switch live at the light. Job done!
Na i looked at that one but the building is a small terrace (old) and the only way of getting to a rose is under the bathroom floor (tiles) and also would have to pull up oak floor (not a good thing )
My plan now is to poss cut into the lighting at any point and run a perm feed from this to my switch !
