2391 V NICEIC - Whats the point in 2391?? | Page 12 | on ElectriciansForums
Guest viewing is limited
Discuss 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
I don't feel that my 44 years can give anything to this site, as you all cry "competent person". A short lived relationship, but i won't be back, but thanks to Westwood for backing up my statement about Elecsa requirements.
That lasted along time :p
Thanks for your comments Andy. I am an Elecsa member, and one of the first requirements was 2391. Enough said!
I used to be an Elecsa member and they never asked about 2391. Enough said ?
Just taken these requirements off NICEIC site:
Scheme Requirements:-
To apply for our Domestic Installer scheme you will need:
• Confirmation of Public Liability insurance to at least £2m
• Certificates of technical qualifications achieved by the Qualified Supervisor
• Hold a current edition of BS 7671 and any other technical reference guides suitable for the work you usually undertake
• Test equipment in good working order and calibrated
• 1 installation sites where you have recently completed and certificated the work
Where do they state 2391 on that?
I think they will accept your cycling proficiency test as long as the cheque clears.
Is this like how some electricians interpret the Regs?
It’s not there, so just make it up?
I am also an Elecsa member, have been for the last 5 years. I do not have the 2391. I only have the 2392. Rightly or wrongly, they have found that a suitable qualification.
On the application form, there's a drop down box to select the QS's highest qualification. The 2391 is not there, nor even the 2392. There is a whole host of other qualifications, including 'C&G Inspect & Test, 16th & 18th', but nothing about the 2391.
ELECSA Contactor's Area - http://www.elecsa.co.uk/applications/application/partPmicrogen.aspx
What's up?...nothing strange. You say you're an Elecsa member, I'm only asking when you became a member and if you were a member of another scheme previously. If so, since when? Did you join up for Part P purposes? If you don't want to answer, fair enough.
I seem to recall I got my JIB Approved Electrician status from Electrician, by passing a multiple choice exam in the late 1970's.
I seem to recall there being a full written exam as well
Hi Andy, you may be able blag your way through filling in a certificate, but without scheme membership, or qualification, no-one will accept it . Building control aren't going to accept a cert from a non qualified person, and insurance companies will just send it back without a scheme membership number.
I've done it quite a few times with insurance companies and even with building control. Most of the people asking for an NIC certificate haven't got a clue of what they are asking for and more to the point I don't think the NICEIC assess the competence of a contractor to inspect and test only to install to BS7671
Hi Andy, so what you are saying, is that because you are a qualified electrician, you are automatically entitled to fill in a cert to cover the work you have undertaken. Why do you think that BS2391 was introduced? Its a level above 1st and 2nd fix installation. To gain 2391, you need to be able to understand the readings that your test equipment has just given you. You need to be able to correlate the readings, to what might be expected. I'm not trying to decry people from thinking that sparks should be confident in what they have installed, but 2391 gives you lots of mathematical equasions that can qualify your readings. Its not that simple. Thats why 2391 exists!
I know of a few colleges where some lecturers based the 2391 course wholly on past exam papers and the lecturers principle was if you learnt enough questions and answers you would get beyond the pass level.
The equations you talk about would they be the same equations you learn while learning to become an electrician as I don't remember any specific I&T equations
Hi, have you ever submitted a certificate to Building control or an Insurance company, under your own name?
Yes I have to a number of insurance companies
Fair comment. Try joinin NIC or Elecsa without it.
Can't think of any reason to join either scam
Hi Andy, NIC, Elecsa and ECA are now owned by Certsure. If you hold 2391, this proves your ability to test and inspect. I don't think having a 17th edition qualification would hack it in court.
The ECA isn't owned by Certsure. The Electrical Contractors Association is a limited company with it's own directors, the ECA is also one of the directors of Certsure LLP
Nope. Memory is a bit hazy, but did my apprenticeship for Electrician (Installation), with the various exams etc. But was asked if 'we' wanted to do exam for 'Approved' status as an add on to the course. And it was multi choice. Can't prove it, but don't remember doing written exam for Approved.
And in this area in Northern Ireland, NIC EIC Approved Contractor is required when it comes to Housing Exec Work, or Entertainment Licences. Neither of which pay very well at all when all is said and done.
Reply to 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Yea that makes sense. Even tho I’m not registered with niceic yet as still need to do the extra training. I’m still signing the qs part?
My older card has it but my newer card doesn’t
