240v Downlighters with LED Dimmable bulbs | Page 2 | on ElectriciansForums
Discuss 240v Downlighters with LED Dimmable bulbs in the UK Electrical Forum area at ElectriciansForums.net
Willenhall
Hi Guys,
Im currently quoting a job to install dimmable downlighters.
Firstly, can I use 240v downlighters with dimmable LED bulbs
Secondly, can I use a standard dimmer switch or does it have to be a low voltage one?
Thanks as always
Dan
you can buy GU10 LED's so yes you can do, a standard dimmer would do it... however as I work at a manufacturer you need to make sure that the LED fittings are compatible with the dimmer....... AKA led is a pain
I instal the complete dimmable led inc driver, costs approx ÂŁ25 .
I used to sometimes fit led lamps only but not worth the aggro and don't perform half as good when using a decent dimmer switch,
Reply to 240v Downlighters with LED Dimmable bulbs in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
