2p + e | on ElectriciansForums
Discuss 2p + e in the Commercial Electrical Advice area at ElectriciansForums.net
evening all, wondered if you could shed some light on a little project. Friend of mine has a forklift and charger and are moving , the existing set up is a blue 2p + e 3 pin plug into a 3pin socket . (Haven’t seen Board etc so not sure what cable) ,
Well there moving to a new premises, and he has a 3 phase board with spare ways, question is as the socket states 230v 2phase + e , how can he achieve this on a 3 phase board?
Never come across this wondered if you can help.
He was advised to fit a double pole mcb in Board and wire into l1, l2 and earth , but unless I’m missing something this isn’t correct and won’t give him 230v
Picture of plug from charger attached
[ElectriciansForums.net] 2p + e
Thanks all, exactly what I was thinking but as I don’t do commercial works I wanted to double check and it now confirms my friend has been told a load of rubbish and they were trying to justify quoting him £780 to do the work when it’s only 1 meter away from fuse board
Thanks everyone will let my friend know
by putting it on one of the phases !
Dumb x 1,List not other curtain twitchier!
Not if the DB is on the other side of a 600mm granite wall,and to go round it is 60 meters extra ;)
See how i'm always trying to give folk the benefit of the doubt....:):eek:
we're not all in Strangeways.:D
Reply to 2p + e in the Commercial Electrical Advice area at ElectriciansForums.net
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
