2p + e | Page 3 | on ElectriciansForums
Discuss 2p + e in the Commercial Electrical Advice area at ElectriciansForums.net
id be ****ed off if i was op and called in a sparky for advice and were then told they needed a 2 phase supply!
someone is having a giraffe
Oh, is this in the zoo then? :)
I have come across old arc welders that are connected across 2 lines of a 3 phase supply. One might reasonably argue that a load connected between 2 phases of a UK supply is in fact a single phase 400 volt load, and that a true 2 phase supply with a 90 degree phase angle between phases is virtually unknown these days, at least in the UK
Reply to 2p + e in the Commercial Electrical Advice area at ElectriciansForums.net
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
