3 Phase Leads | on ElectriciansForums
Discuss 3 Phase Leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
We have them at work , buy the scafftag type label for test dates they tie wrap on and are very hard wearing
Give it an I d
Visual check , must have metal braiding if on construction site or engineering shop floor etc (type 7 cable) or sy which we like for portable equipment ( some people don’t like to use )
Continuity tests
Ins resistance
Fill out ppm sheet
Store in folder or on pc
Job done ✅
Also,check for correct configuration,as a lead with a male type plug at both ends,could pass inspection,in regard of how it is fitted.
Industrial sites are notorious,for "modified" leads,with the 110/240 16A "universal-with-the-nib-removed" being common :)
Just noticed where the OP is...gonna be a voltage drop,to there :)
That old chestnut
Give it an I d
Continuity tests
Ins resistance
Fill out ppm sheet
Job done ✅
As written in electricity at work act
Keep records of electrical equipment that may cause harm and keep in safe working condition
This is how we comply with national grid , united utilities etc
And we get audited on this to make sure we are complying
Give it an I d
Continuity tests
Ins resistance
Fill out ppm sheet
Job done ✅
The dislikers what do you suggest
Reply to 3 Phase Leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
