K
kant
Can any one tell me if i need to put rcd on 3036 cu if I am just changing socket faces cause i was told i did?
Discuss 3036 with RCD in the Australia area at ElectriciansForums.net
First photo shows main earth attached to incomer with bonding clamp, reckon that's a code 2 on PIR
Yep seen that, heard you loud and clear..
But i dont think i have a 1361 main fuse..
and i always see this ka rating 1 to 4 on 3036 fuses but which is it... 1,2,3 or 4?
Providing earth loop complies with 41B1 in BS 7671 then you don't need an RCCD.
Do cables buried at less than 50mm on a PIR mean an RCD should be present. Not sure it does. Otherwise 90 % of DBs in UK would need replacing. Sockets should always have an RCD but lack of them on a PIR does not constitute a code 1 unless external sockets lack RCD protection.
Reply to 3036 with RCD in the Australia area at ElectriciansForums.net
