View the thread, titled "30A JB's and 32A ring final circuits" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
On that line of thought is a socket behind a built in appliance accessible? Do you fit a socket with maintenance free terminals rather than screw terminals? Do they even exist?
Because clearly a JB, non MF, under a floodboard is not accessible - why would you think it is?
you are an absolute joke of a person, im sure you are just trying to wind me up,
and to answer, inaccessible 'to me' means i can not possiblty access that point
accessibly without damage would be a much better way to state this situation in the regs to avoid all this wasted time trying to work out what it means
the regs book becomes more like the bible each day, some people believe in one solid message and wont budge , and the rest see all the contradictory and vauge thigs written whithin
now... Murdoch one last time.... can i have a JOINT (MF or not) above the fuse board in plain sight (in a nicely accessible place just for you) that is rated at 30A, is that 30A joint ok for use on a 32A RFC???
Just making sure that you realise that under floor boards is NOT accessible.
Next time you are doing fault finding, and you worry there may be a faulty JB under the floor, where exactly will you start cutting up the floor?
Not even in the same ballpark as a JB hidden under a floorboard. I agree with Murdoch, if it's a JB under a floorboard, and is not clearly marked, then it's to all intents and purposes "inaccessible".
As I said earlier, MF kits are cheap, reliable and quick to install. No excuse for not using them nowadays. Any guy who tells you to hide JB's under a floor, rather than using approved MF connections and enclosures does not understand the regs.
i would exactly start cutting up the floor after i use a fluke meter to determine exactly how far down the cable the fault is the make my best educated guess as to the route of the cable and work it out, i mean generally i would 'think' about it but i guess 'thinking' is a concept that you never quite grasped cus when monkey gets told 'do A,B,C it cant fathom 'D'...
agaian im all for using the MF connections im under instruction to use JB's
Split Jugular if you take that view of things then nowhere is in-accessible.
You could bury a JB under 10ft of concrete but it becomes accessible with a jack hammer and a mini digger!
It comes down to common sense, I would ask myself the following question:
"If there was a fault on this circuit at some point in the future would I (or someone else) be able to find the joint without having to destroy the house in the process"
If the answer is yes then the place is accessible, If the answer is no then it is not.
Simple as that really.
My opinion on this.. yes you can use 30amp joint box on ring circuit. As long as accessible (without moving furniture,carpets,floorboards etc. If no other option but to use a JB then maintenance free type. As for heavy appliances sited directly in front of sockets, badly designed, said socket should be switched via a spur point.
My question about sockets behind appliances was not about the isolation of it but accessibility of the connections. The reg being debated is about all screwed terminals not just JB's, so the terminal screws of the socket behind the fixed appliance are also covered.
I'm not sure that a trap cut in the floorboards and screwed down with its location noted counts as inaccessible. BS 7671 does not require a welcome mat above the joint. I think it's a matter of opinion.
yeh thought as much, this is what the NIC man had apparently told him on the inspection visit last friday, am i right in saying that during an NIC visit they may say something like this to challenge your knowlege of the regs and this would be an invitation to discuss whats right and wrong, being that the regs are not a statutory document and in a sense they are just theory, surely arguing this would prove to the NIC man that i have sound reasoning behind my work,
ive heard from other collegues that they were asked why back boxes were not earthed (apparently this has been dropped in the regs)
"why are back boxes not earthed?"
"because they dont have to be"
"what about when the face plate is taken off the box is then not earthed!
"you shouldnt work on an installation whilst it is live"
the last line my friend said apparently seemed to be the answer the NIC man was looking for
Line 4, where did that come from?
Boydy
FFS is this thread for real??
JB's under floors are not accessible. Its a test of common sense - the thing that a few people on this thread are missing!
Reply to the thread, titled "30A JB's and 32A ring final circuits" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
SplitJugular,
Dan,
