I
irishjohn
No you have lost me.
The FIT rate is decided by the TIC. You need to understand the statutory definition. It is not the sum of the installed panels.
The MCS form asks for the DNC. The advice they then give in the help document is:
"For the declared net capacity field, enter the kW peak (kWp) capacity of the system once it has been installed. E.g. a PV array which has ten 200W will be a 2kW system, therefore enter in 2.00 you will not need to enter the units, only enter the figures."
.....which is NOT the DNC
Say you have a panel capacity of 4.2kW on a 4kW inverter. The TIC and DNC according to the statutory definitions is 4kW and the owner should get the less than or equal to 4kW FIT rate. If you were to put 4.2kW on the MCS form, representing the installed panel capacity, I am willing to bet the owner would struggle to get the 4kW rate. So I would put the DNC which is what they ask for and assume their advice is wrong.
Regards
Bruce
I would never assume the advice from the people that make the rules or pay the money is wrong, that is just unprofessional. What would be wise is if you asked the Electric companies, MCS, Ofgem and NICEIC.
Having made these enquiries to all of the above including NAPIT, they all confirm TIC not DNC. Also as I mentioned, over 4kw TIC or DNC is G59 which every way you look at it.
4.5kw is 4.5kw whichever way you look at it. If you dress this up as 4kw you will at some point be found out and may have to pay back all the additional benefit you have received and the person certifying may lose their MCS accreditation.
Check before you act. DYOR.
