60A Main fuse & NIC assesment? | Page 2 | on ElectriciansForums
Discuss 60A Main fuse & NIC assesment? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
nothing in our regulations states that it is illegal
the fact there is a big sticker on the fuse with NEEB / NEDL (or what ever area your in)property and tampering with this equiptment may result in prosecution or words to that effect
seen a fuse with warning printed in German it said " Gerfingerpokin Verboten"
amazing how these seals seem to drop off conveniently just before we staret a job.
Ive read in the OSG that I should check what length the meter tails can be and what CSA they should be too; does anyone bother with this?
Cant remember the page number but its near the front?
He only brought the flat a in october and it looks like its recently been re-wired, hence possibly why theres no seal.
Johnny G, yeah I'll contact them, but wasnt sure if they would help unless your a current member, which I'm not yet
Reply to 60A Main fuse & NIC assesment? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
