63 Amp Isolator | on ElectriciansForums
Discuss 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
Surrey
I'm running a 63A supply for a cooker and need to have a local isolator.
Apart from having a 63A main switch in a small enclosure, is there any thing else I could use which is discreet to put in the back of a cupboard.
No idea what reg no. it is but it does say something about being able to secure the circuit so that it cannot be turned on, which isn't a mcb. IMO
Nonsense man! ÂŁ1000 heading your way if you can find a reg that would prevent you from running directly from OCPD to cooker.
P.S. An MCB is a perfectly acceptable means of switching off.
Reply to 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
