63 Amp Isolator | Page 3 | on ElectriciansForums
Discuss 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
Surrey
I'm running a 63A supply for a cooker and need to have a local isolator.
Apart from having a 63A main switch in a small enclosure, is there any thing else I could use which is discreet to put in the back of a cupboard.
I know my NICEIC inspector would be telling me I shouldnt be doing it. He made a comment when I installed a cooker isolator switch in a cupboard as per customers request.
Do you ever have inspections?
I couldn't give a monkeys what your scam inspector tells you especially as he's talking out of his ---- orifice! Seems the pedestal you've put your inspector on is just a little too high.
I do have inspections funnily enough, in fact the last inspection I had I recall a conversation between myself and my inspector where I was teaching him about capacitance. He clearly had a lack of fundamental knowledge regarding the scientific principles of electrical installation and couldn't understand why I was using one on a particular circuit.
If in doubt, shove the regs book in their face, because that is what we work to, not 'club' rules!
I would always install an isolation switch to a cooker. I will mark as an observation/issue if a cooker had no isolation too
If you would code a cooker with no local switch then you've no business carrying out EICRs.
A mention would be all it would warrant, if that.
I dont think this is setting a good example to out eastern european or Electrical Trainee friends.
I couldn't give a damn about what example I'm setting! If some block head or 5 week chancer is going to bad mouth my work or my methods then god help them! And anyone with half a brain that goes in and codes my work because I haven't done something that isn't required anyway has no business calling themselves an electrician. Every piece of work I have ever done complies with BS 7671! I have fitted cookers with AND without 'local' isolation. This argument is meaningless, I am right! Best practice and personal opinion are completely different to what is required by regulation. Besides, we're talking about a bleeding cooker here! A cooker! Hardly talking point of the decade is it?!?
If it makes the OP happy, whack a nice big Glasgow fused switch next to the cooker, who cares, tell/lie to the customer when they see it and kick off that it is a 'REQUIREMENT' and that you don't care one jot about being reasonable and that NIC rules are the bees knees! No one cares about the fact that they've spent ÂŁ10k on their new kichen and they've now got to put up with that ugly grey metal box on the wall, just as long as it can turn the circuit off in the event that at some point in the next 30-40 years a N-E fault occurs with the cooker.
RVM, do what you want mate, the info is there. You don't need local isolation. Whether or not you choose to install it is entirely up to you and you're a$$ is covered either way.
Calm down your gonna burst some thing.
i think a Glasgow is a bit extreme lol
wish I hadn't asked now I think I will stick to my little main switch in an enclosure in the cupboard
As the BGB doesn't call for local isolation, the only reason I can see you being obliged to fit it is if the manufacturers instructions call for it. Or if the customer wants it. Or if the switch is gonna be used for functional switching. In the event of a fault, a DP isolator might be handy, but the absence of one is hardly gonna fox a spark who knows what's what!
That's my two penneth, for what it's worth.
I'm calm mate, don't worry. I don't mind a bit of civilised discussion as to the pros and cons of installing or not installing a local isolator for a cooker, but what I can't abide by is the completely uneducated, amateur and frankly rude reaction by some that my work is somehow setting bad examples.
Like I said, you have the info you need, you have a choice of options, what you choose is up to you :)
Thank God! Some reasoned response at last! Lol
Just being logical I suppose. Thinking more broadly about isolation (not cookers), the times I generally fit it are when it is specifically mentioned in the instructions, otherwise it is often a side affect of fusing down. I have been known to fit a switched FCU when a non-switched would do, just because it was what I had to hand. :)
Reply to 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
