Dizzy_Maskell
Went to look at a house to buy few months back and no gas so needed all electric.
Re wire needed so looked into new electric heaters, ovens, showers, boilers etc.
Noticed supply cables to consumer unit about and cut out seem about 6mm and cut out was 60 Amp.
Was wanting to change to 100 amps or at least an 80 due to thinking at some time no doubt everything will be on and did not want to risk main fuse popping so called DNO and asked then can I change to a 80 Amp or 100 from the original 60.
I was told ALL cables in UK to houses are rated at 45 KVA.
Not sure the BGB cable size guide agrees with the amount of load.
So does this mean I can start using 6mm to feed 150 Amp and more ???????
