You cannot not get a shock between N & E unless its connection at source is broken.
If its connection is broken the live will try to return to earth through you (if touched), giving you a shock.
Yes there will always be negative voltage on the neutral not measurable unless supply is under load.
This is due to the cable resistance.
Thanks for your answers, really appreciated.
I guess what I am really stumped at is how can the current flow in the neutral if it is at zero volts.
There is simply no EMF to drive it along, this is where I am stuck.
If you touch the neutral at your light switch in your house it is at 0 Volts and if you touch the neutral at the transformer end it is also at 0 Volts so how does current move along it?
There must be some volt drop but just not enough to notice.
Time for a beer me thinks.
Draw a simple battery/lamp circuit with the -ve of the battery & you connected to earth.
Imagine a 250V battery.
The same current flows around that circuit at any point, irrespective of the voltage (at any one place)
You'd get get a shock from the +ve side of the lamp because there is 250V to you & earth, on the -ve side of the lamp there is 0V.
Negative in relation to earth.
No because the volt drop would be negative to the neutral.
