AC theory
You cannot not get a shock between N & E unless its connection at source is broken.
If its connection is broken the live will try to return to earth through you (if touched), giving you a shock.
Id disagree with that, its very possible to get a shock in that way
Thanks for your answers, really appreciated.
I guess what I am really stumped at is how can the current flow in the neutral if it is at zero volts.
There is simply no EMF to drive it along, this is where I am stuck.
If you touch the neutral at your light switch in your house it is at 0 Volts and if you touch the neutral at the transformer end it is also at 0 Volts so how does current move along it?
There must be some volt drop but just not enough to notice.
Time for a beer me thinks.
Draw a simple battery/lamp circuit with the -ve of the battery & you connected to earth.
Imagine a 250V battery.
The same current flows around that circuit at any point, irrespective of the voltage (at any one place)
You'd get get a shock from the +ve side of the lamp because there is 250V to you & earth, on the -ve side of the lamp there is 0V.
but what about the flux giving back emf:hanged:
Well it wont quite be 0 V, therw will be some potential
How do I start this?
N & E are at the same potential supposedly but the line conductor RMS voltage rises to 300+V positive and drops to 300-V negative 50 times each second. Giving 100 changes per second. The average is 230V constant to neutral/earth. (Look up RMS voltage).
More to follow if you want.
La Poste,
Knobhead,
