Adding circuits to a full DB | on ElectriciansForums
Guest viewing is limited
Discuss Adding circuits to a full DB in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
what's your take on adding circuits to a full DB.
Warehouse unit,3p DB,full to capacity,new 3p circuit to be added,client refuses to upgrade DB.
Would you reconfigure a couple of circuits to allow for this new circuit.
No, tell him to get his hand in his pocket.
see if any two lighting circuits can be put into one breaker. sometimes the lighting circuits are split for convenience e.g upstairs and downstairs and it isn't always unsafe to put them into the same breaker. otherwise just tell him you want to do the job properly and if they arent prepared to pay for it then run away
Agree,thanks
When he expresses his disgust with shutting down his site for works perhaps remind him that doing it properly this time round and installing a DB with many spare ways will prevent this problem from happening again in the future.
Edit:
Another option could be to consolidate a few 1P circuits into their own DB fed from the exsisting 3P DB. You could move 4 lighting circuits over to a 1P DB and have enough ways for a 3P MCB and 32A SP MCB to feed the new DB.
Yea that’s the best option,will need to switch off & reconnect tails etc.
He’s not gonna be happy,work will either be @ night or weekend.
You are going to lash a new board off the live side of the existing one??
If you’re doubling up a couple of lighting circuits here and there, and maybe a single point spur onto a ring.... you’re going to have to reconfigure a lot of other circuits to get 3 together for a 3 phase circuit.
No bodge job, @cliffed Tell him it needs to be done right. Got to keep those phases balanced and all that.
Edit:
Agree,hopefully go for the new Db
Yea,he’s gonna have to go with the flow.
Reply to Adding circuits to a full DB in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Recommended Sponsor News
Hi everyone,
