Advice on consumer unit replacement. | Page 2 | on ElectriciansForums
Discuss Advice on consumer unit replacement. in the UK Electrical Forum area at ElectriciansForums.net
Amersham
Hi, I have an issue I cannot get my head round.
I have been asked to replace a consumer unit, and the circuits are run in steel conduit with singles for live and neutral and using the conduit as the earth for sockets and lighting. There is also an MICC cable supplying the cooker.
There are two conduit’s entering from the bottom of the CU, and one conduit from the top of the CU along with the MICC entry.
My problem is modern consumer units are taller than the old ones, and I don’t know if it is practice to cut and rethread steel conduit fixed in place and containing cables.
I would consider mounting the new consumer unit in front of the existing unit so the conduit and MICC does not need to be disturbed, but my worry is that once the new consumer unit is in place, the earthing for all circuits is only accessible by dismantling the current consumer unit.
Any Advice?
Regards
Ps Sorry about repeated images, but there is no way to remove an image if added by mistake and no way to reset the add new thread that I can find.
[ElectriciansForums.net] Advice on consumer unit replacement.
Yeah I keep looking at them, Im not sure.
I am certain, the MI is if you look at the sleeving. One of the bottom entry conduits appears to be terminated at an oversized entry. They also have lockouts locking the conduit to the couplers, that is definitely a method I haven't seen for years. State of those conduits though I would think a rewire is probably in order.
Yes those lock nuts do give a clue.
If I was asked to quote for that, I would put a very high price in ...... so that some other mug does it.
I was the other mug. A little old lady that has been told by her sister that it looks dangerous and so she insists it is changed.
I tried an EICR hoping to be able to convince the lady that the installation is not significantly more dangerous than when installed, but found problems that mean I must recommend a CU change, although I actually believe it would be better to make a few minor repairs and not change the consumer unit.
What problems to suggest a CU change.
Reply to Advice on consumer unit replacement. in the UK Electrical Forum area at ElectriciansForums.net
2 3
