Advice on garage supply | on ElectriciansForums
Discuss Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Hi i'm looking for some advice, i have been to look at a job to wire a garage. In the garage will be 3 double sockets and 3 lights. What my idea was is to run a 6mm 3core swa from a non rcd protected way on 40amp mcb to 40amp rcd double switch in a 2way garage unit which will be feeding a 20amp radail and 6amp lighting circuit. The length of the swa will be approx 22m run under the floor cavity and out to garage.
What advice are you looking for Sparks321?
Three chickens and a varnished stoat?
Earthing arrangements? Any other services which require bonding? Any potential for EV charging point?
Hi mate. welcome to the forum.
I take it you are notifying this work?
I suggest you answer the questions above then we can comment better.
Reply to Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
