Advice on garage supply | Page 2 | on ElectriciansForums
Discuss Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Hi i'm looking for some advice, i have been to look at a job to wire a garage. In the garage will be 3 double sockets and 3 lights. What my idea was is to run a 6mm 3core swa from a non rcd protected way on 40amp mcb to 40amp rcd double switch in a 2way garage unit which will be feeding a 20amp radail and 6amp lighting circuit. The length of the swa will be approx 22m run under the floor cavity and out to garage.
Difficult sometimes, to keep stum isn't it.
We are here to give advice... It's just that sometimes the OP's don't like our advice or don't answer the questions so it's hard to advise them properly.
Hi sparks 321
To do any job,the person needs to understand everything that's involved
Cable calculations are needed for cable size, protective device/s,anticipated load,earthing arrangements.
These need considering to design what you intend to install
Then there are the practicalities of getting your tools out and doing that installation
Ask specifically about any point you want assistance with and explain the decisions you have made,easier to give help when both sides understand each other
I'm just looking for advice as i'm trying to pick little bits of work up myself. So what would you suggest?
I'd suggest you forget the idea while it's still not too late.
I have said what i was going to do in my first post. Earthing is tn-s, everythin that side is new and there is a dual rcd board. I think the biggest load will be a tumble dryer and other sockets just general use with one out side socket for lawn mower n obv will b an ip rated outside socket and the board feeding it will have a main rcd switch
Yes will b tested and notified. Thought these forums were for help n not for giving abuse
We do give out help mate...
We have to judge the person who is asking the question, see what electrical knowledge they have then we can answer the question relative to their knowledge.
If you are an electrician then I presume you have done all the cable calcs. Were the results satisfactory?
If you are not sure then show us the calcs you have and we will correct/add to them.
Going off that a 6mm swa will carry 42a? And will not be needing more than that as lightin is nxt to nothin and the biggest thing to be used in sockets is tumble dryer and garage is not used for power tools etc. Volt drop over that distance I wouldn't say will affect anythin usin a Swa. What other calculations are you looking for?
Again, we are happy to help but if we just give you the answer you will not learn anything.
Is is just the cable size you are questioning?
There did you get 42A from? Is this from the manufacturers data sheet?
Show us your workings out and we can advice.
Reply to Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
