Advice on garage supply | Page 3 | on ElectriciansForums
Discuss Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
Hi i'm looking for some advice, i have been to look at a job to wire a garage. In the garage will be 3 double sockets and 3 lights. What my idea was is to run a 6mm 3core swa from a non rcd protected way on 40amp mcb to 40amp rcd double switch in a 2way garage unit which will be feeding a 20amp radail and 6amp lighting circuit. The length of the swa will be approx 22m run under the floor cavity and out to garage.
Yes and Punctuation.
Yes will b tested and notified. Thought these forums were for help n not for giving abuse
They are here for Electricians to discuss challenges in our Industry.
Sorry you feel a little upset at the responses, however we just know from a post whether the person writing it is competant or not. I have to be honest, I get the impression you are out of your depth.
If you can tell us a bit about yourself it may help us when we reply
Yes cable sizing. Looked at table it'll b method d and current carryin capacity 44a. A little help wouldn't go a miss here
Hello, Yes I looked at the appropriate table and in my opinion it was method D. The current carrying capacity is shown as 44 Amps. I would appreciate it if you could all help me with my problem, Thank you.
But you keep avoiding questions that you have been asked. What are your volt drop calcs? Just saying 'it should be ok on a SWA' is not a calculation. And what is the earthing system of the installation?
This is a good forum, but it's a two-way thing!
Not out of depth and you have to start somewhere in learning how to design a system.
I'm happy to help you. This is why I'm asking the questions.
I will not give you the answer thought. I would like you to work it out, with our help. That way you learn things.
How long have you been an electrician?
What qualifications do you have?
This way we know your knowledge base and can reply accordingly. We all love to learn.
Volt drops calcs i could do with studying up on if am being honest,
We can help with that. Look up the formula for volt drop.
Post it on here. Under that write it out again but replace with the figures you have. Look at the manufacturers data sheet or BS7671 for cable for Volt Drop figure.
Do you have a the BS7671 book?
Reply to Advice on garage supply in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
