F
fire
wanted to install 2 mains smoke alarm (1 upstairs and 1 down stairs) and a mains heat detector in the kitchen.
all circuits are on rcbo so wanted to tap into the lighting circuit and just install it next to the ceiling rose saves me taking our floorboards or do chasing.
is that a good idea?
Onsite guide page 65, wiring of smoke and heat alarms paragraph b ..... or supplied from a local, regularly used lighting circuit (there should be a means of isolating the supply to the alarms without affecting the lighting
I'd guess so that they can be serviced in the dark :)
oh well stand corrected...! service an Alarm .... hmmmm test button/hush button
for the sake of retro fitting in to a preexisting house i would bang them in as per the ops suggestion...! on a new install yes seperate circuit
rather have smokes than no smokes!
Hehe, more likely where one has failed in the chain and needs replacing ... most these days have detachable bases that are interchangeable though, so that may be sufficient isolation.
Hi TQ,
Is this not taken care of by un-clipping from the base (on the types I normally fit) ?
Because I usually install them similar to the OP (on existing), agreed on a new install, to fit the 'keyed' type isolator.
Ps. I Posted too slow TQ, you have already answered, thanks
With the exception of full rewires or newbuilds then doing as you suggest is standard practice
When you say fitted next to the ceiling rose you should note that smoke alarms should not be fitted within 300mm of light fittings or walls.
the smoke alarm and heat detector i have has three wires, two of them are live and netral what happens to the 3rd one (white wire)?
alarms
Security Alarms, Door Entry and CCTV (Public)
fire,
Richard Burns,
TrueNAS JBOD Storage Server
