AM2 | on ElectriciansForums
Discuss AM2 in the The Welcome Forum area at ElectriciansForums.net
M
Matthew terry
Morning all, Matthew here
Have my pre AM2 this week and then the real deal starts Monday! So I signed up to look at any previous posts about the AM2 ( Pobably a few on here id imagine)
Welcome aboard Matthew, site:electriciansforums.co.uk AM2 - Google Search - https://www.google.co.uk/search?q=site%3Aelectriciansforums.co.uk+AM2&oq=site%3Aelectriciansforums.co.uk+AM2&aqs=chrome..69i57j69i58.6973j0j7&sourceid=chrome&ie=UTF-8 - Some searches from Google. Change that to "AM2 Assessment" to find assessment related threads and posts. You can add the year to the search too if you want just the more recent threads and posts. :)
If you have any specific questions, post in the main electrical forum and I'm sure some of the lads will be able to help a bit.
Best tip I can give you for the AM2: Write everything on the back of your schedule of test results. R1+R2 at each point, Zs at each point, RCD values x1 and x5, FPC / FSC, 3 phase double PSC value, the more the better.
Ring Circuits:
Use the formulas to calculate expected R1+R2, Ring Continuity for the neutral / earth and Zs
Expected R1+R2: r1+rn /4
Expected Zs = Ze + (r1+r2)
Expected Ring continuity for Neutral: r1 = r2
Expected Ring continuity for Earth: r2 = r1 * 1.67 NOTE: Assuming you are wiring your Ring circuit in 2.5mm If not take the line and divide it by the earth. Example: 2.5/1.5 = 1.67
Cross link your ring final circuit and test each socket for the same reading or a reading within 0.05 Ohms.
Anything higher than this is typically a spur from another socket but not always.
Sometimes it's worth plugging your tester in and out a few times to clear the muck off the brass in the sockets.
Mark the outgoing and incoming ring cables in the distribution board for ease of testing later on.
Testing:
DONT FORGET TO NULL YOUR TEST LEADS AS IT LEADS TO FALSE VALUES
DO THE TESTS IN THE CORRECT ORDER:
RING CONTINUITY, CPC, IR, Zs, RCD, Polarity, RCD Test Button
IR test should be done at double the working voltage. 500V up to 500V with the exception of SELV / PELV (250V)
Make sure nothing is plugged in and any neon indicators / lamps are removed from the circuit. Switch all light switches to ensure all the cables are IR tested. A lot of people forget to do this with 2-way lighting circuits. Personally, I like to test at 230V first to make sure I get a good reading before pumping 500V down the circuit and blowing up someone's appliance.
Ensure the RCD Tester is set to the correct mA for the RCD /RCBO, 30mA usually (Could be different for you)
Safe Isolation
10 TESTS FOR 3 PHASE
L1 - E
L2 - E
L3 - E
L1 - N
L2 - N
L3 - N
L1-L2
L2-L3
L1-L3
N-E
3 FOR SINGLE PHASE
L-N
L-E
N-E
Make sure you select the GS38 compliant tester and proving unit and follow the safe isolation procedure step by step.
I could keep going but I would be here all night, maybe I will get around to making A tips and tricks guide some time ;)
Honestly a lot of the things I am telling you, you will be told on your pre AM2 but you need to ensure you do them on the day of your exam.
Good Luck!
Thanks all much appreciated! Two days of pre am2 complete, alot to take in regardless of containment taken out, everything has to be wired as they spec and tested how they want it! Like a global IR test with the ring disconnected (earths still connected neutral and live blocked separate) then tested againt the the outgoing side of the main switch ( L-N L-E N-E of the ring, then L- L1 L-L2 L-L3 N-L1 N-L2 N-L3) thats new to me! And i cant remember if we had to disconnect the lighting feed or just switch it off via the mcb during the global IR! Also a lot of formulas thats need to be wrote down on scrap notes otherwise you will fail. Eg motor overload convert Kw into W then divide by 3 ÷ 230 x 1.1. Load of nonsense but there we are. To say my head hurts would be puttint it lightly!
Reply to AM2 in the The Welcome Forum area at ElectriciansForums.net
L
Electrician UK Electrician looking to move to Australia 2025 UK Electrician looking to move to Australia 2025 Hi Everyone Looking for some...
lewish121
L
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
