There should be a bolt for your crimp to connect on to on the backbox. At least there was when I did my AM2.
ALSO Just remembered something else, Your ring final circuits, how have you done your earth connections?
If you look on the back of the socket they specifically have 2 earth terminals, 1 for one earth in and one for out.
Usually, you do this for computer circuits but they specified we needed to do it in the exam.
Nope, nothing on there its only like a metal back box with a front cover which has a photo of a motor! Lol also the socket we are using only have one earth terminal in the back so i shouldnt have that problem really :)
Inside my pre AM2 pack, we were told to use the braid for an earth of the extraneous conductive part, namely the braid. The braid must not be used as a CPC. The picture below the text shows the braid sleeved green / yellow connected to the backbox.
@LeeH What would you sleeve the braid? Or would you leave it?
The braid wouldn't be an extraneous conductive part.
"The galvanized braid is not considered suitable to use as a circuit protective conductor (CPC) for the cable, and it is also not considered to be an exposed conductive part.
The reason why it is not considered an exposed conductive part is that the cable meets the requirements of Regulation 412.2.4.1 of BS 7671 for protection against electric shock by means of the protective measure of double or reinforced insulation."
Reference: Q & A of the Day – What are the earthing requirements for using SY cable on single- or three-phase extension leads? - http://www.voltimum.co.uk/articles/q-day-what-are-earthing-requirements-using-sy-cable-single-or-three-phase-extension-leads
You need to do what they say to pass, but as it's not protective G/Y should not be used.
It's normally used as a fuctional earth, SY is commonly used to reduce EMI when using variable speed drives. Cream is the suggested colour.
And just to confuse you, SY is not really a suitable cable for VSDs as you cannot buy it without an internal CPC. It's non symectrical.
You need to do what they say but as it's not protective G/Y should not be used.
It's normally used as a functional earth, SY is commonly used to reduce EMI when using variable speed drives. Cream is the suggested color.
I agree cream would be the color to use on a site (Table 51 confirms this), however the pre AM2 we were specified to use green /yellow and I passed using that :)
Being as this is for his AM2, I recommended he use green / yellow because I know I passed using it.
Worst case, if you fail any unit, you just retake that unit. Lets hope it's not the installation if any because that's the most time consuming and expensive to retake.
When I took mine I was more worried about failing and having to pay to retake. Not to mention the 2 hour drive every morning to the nearest test center.
Just a heads up when you get the email, they are evil bastards, you have to do a survey before you get your results. Then you are welcomed by a long list of criteria and whether you passed them or not. If they are all green, your good :)
I received an email from NET last week, so it wouldnt be in my junk ( but i have checked, nothing!!)
Well done!!!, as for the online exam, its open book so you need to get used to where everything is in the book. I did this by sticking postit notes in the sides until i learnt where things are.
Hi
Are we aloud to take our own GN3 and OSG into the exams? If so are we aloud them to have sticks notes on side? Just for page refference?
Hello, You are allowed the following books in the exam:
BS 7671 IEE Wiring regulations
IEE On Site Guide
IEE Guidance Note 3
Electrical Installers guide to the Building Regulations
The best thing for you to do is get to know where things are in each book. I used post-it notes to learn. If you can navigate the books and have a general idea where things are, you will find the exam easy. For instance, my exam had some questions on special locations, I know this is part 7 of the regs book so I jump straight there for the contents. Find what area I'm looking for, perhaps a swimming pool, see what section it is and go to the relevant page.
I have not seen any online exam practice papers (I didn't look hard), however I recommend you find an online 17th edition wiring regulations practice exam to give you practice at finding things in the books
Something like this:
17th Edition (2382-12) Online Exam Simulator - http://www.proprofs.com/quiz-school/story.php?title=17th-edition-2382-online-exam-simulator
All fault finding is, is testing. The only difference is while testing you will find a bad reading indicating a fault. All the tests are the same and the same process should be undertaken.
For example, if you have a circuit that trips the RCD when you turn it on, it would indicate a Line to Earth Fault, so you would carry out an insulation resistance test at the correct voltages and compare the values to Table: 61. Once you have located the fault, repair it and then re test the circuit.
Wondering is the S plan wiring does it come with the diagram or have to memorise the diagram that Jamchiv01 had posted.
The CAT 5 have come into contact with through cabling and then the electrician's doing coms terminate it.
Assessment is near just trying to watch YouTube for visual practise..
Thanks loads for the help
You get the s plan wiring diagram given to you in the exam mate
Which cable size using on the S plan wiring....1.0mill and climping tool to be used...
What's the colour coding when terminating CAT 5..which colour comes first..
Hello, you will most likely use 1mm squared Heat resistant flex
What do you mean by crimping tool to be used? The conductors usually terminate into terminal block in the wiring center.
CAT 5 should be wired using one of the 2 standards. Best to stick with what's on the back of the faceplate you are using, just make sure that they both match.
Hope this helps.
Matthew terry,
mambo,
