T
thekingiam
Just read a blog stating all cu in domestic to be fire retardent is this true and does that mean all cu to be metal
I remember being told by a scam inspector that RFCs were going to be banned when the 17th was introduced. He assured me that this was definitely going to happen.Fair enough, they lied to us all were dooooooomed....
Do you have the truth then, out of interest?
A bit miffed as to why they would get 150 sparks in a room, and then lie to them, when a couple of guys on t'internet know the whole truth.
Am i being naive?
Got to justify the fees to you somehow.A bit miffed as to why they would get 150 sparks in a room, and then lie to them, when a couple of guys on t'internet know the whole truth.
Right, for the umpteenth time, no, new CUs and switchgear do NOT need to be metal.
However, it will need to be 'fire retardent' from January 2016.
The 3rd Amendment comes into effect on July 1st 2015, but, due to manufacturers pressure, the requirement for fire retardent CUs has been put back to 2016.
It makes one wonder - if they are dangerous in 2016, why arent they dangerous now?
Anyway, there is also a new BS 61439 (iirc) coming in early next year, which will require CU plastics able to withstand (again, iirc) 950 degrees, rather than the current 650 degrees, and also be self-extinguishing.
So, all CUs will need to meet the new BS61439 early next year, which will also mean they will pass the new BS7671 fire retardent regs.
Yes!!!
No one seems even slightly concerned about all those plastic things that the metal box will contain or the PVC insulated and sheathed cables with are terminated in it.The requirements have changed since the DPC was issued.
All BEAMA members are going steel, their opinion as a trade body & their members is that only steel meets the intent of the reg.
Please give a link to your ideas?
All correspondence from The IET has been about 'fire retardent', not 'metal'.
You read the IET forum, so know what has been said about it there.
Geoff Cronshaw has been quoted recently as saying "CU's will need to meet BS61439-3.." which will make them more fire resistant.
hmm, might go back to micc for fire alarms at this rateNo one seems even slightly concerned about all those plastic things that the metal box will contain or the PVC insulated and sheathed cables with are terminated in it.
That will depend on the fire rating of the ceiling, a suspended ceiling will require metal fixings.As I said before that is total nonsense. Sure there are "some" situations where this is relevent but ALL plastic trunking or conduit - absolutely not and as for above ceilings - that is tripe.
Will make the forum a intreting place if it was ever to make a mass come back, can see it nowhmm, might go back to micc for fire alarms at this rate
Does that mean good bye plastic clips and ty wraps?
Reply to the thread, titled "amendment 3 metal consumer units for domestic" which is posted in Domestic Electrician Forum on Electricians Forums.
