G
gap30
Access dependant, your enclosure should be IP2X, therfore finger safe in theory. Add the line check and cover/shield live accessable areas. You should also be able to get your L and N probes onto the incomming terminal screws of the main switch, which will be live, therfore no need to close and open the switch to perform the test, making it a bit safer.
yes mate i have never done that i usually just open the main switch carry out the test and then reconnect earthing conductor and then close main switch
The question in full so you can get a better idea
a periodic inspection is to be carried out on a residence with gardens front and rear, which is to be used by a housing association for residential letting.
the original installation was carried out ten years ago, and a kitchen and bathroom extension was added five years later when mains gas was installed to the property. There are no forms of certification or circuit details available for the original installation or the additional work.
the installation forms part of a 230v, 50Hz TT system with a PFC of 1.3kA. A 100mA RCD which also serves as the main isolator, is installed in the consumer unit
