An installation has been seriously overloaded and requires investigation. State
a) the type of inspection and test that would be required. (1 mark)
b) two areas which require close inspection as a result of the overloading. (2 marks)
could this be any 2 from the scope ie SADCOW
Safety,ageing, deterioration, corrosion, excessive overloading, wear and tear
The SADCOW just leads you back to the question really, the areas for close inspection would be areas that might have sustained damage from the associated overheating:
Distribution equipment and as Spin suggests, conductor insulation properties.
I could make a good case for close inspection of overcurrent protection too, how did that installation become 'seriously overloaded'?
