Annoying simple circuit | Page 2 | on ElectriciansForums
Discuss Annoying simple circuit in the UK Electrical Forum area at ElectriciansForums.net
L
Ldm
hi ladies and gents
I have opened a ring final circuit to add 3 sockets. All was goin well till I powered it up and it keeps tripping. I have tested and IR comes back fine. continuity also fine, all test readings are fine. the circuit has 9 sockets and has a 32 type c rcbo. any other info needed please ask.
sorry for the short message but my keyboard is dying.
thank you
How do you know this out of interest? Not exactly proper practice IMO. [emoji2]
ive tagged along with several firms in the past and been on building sites etc where they dont bother.
on a side note, have you guys seen demma installs, to say there a birds nest is an understatement
brand new bms installs with hundreds of cables tywrapped to ceiling grid etc with no support, i would feel embarrassed installing it but the clients dont mind it because they dont have to pay them for containment!!!!
The correct way to test a ring final circuit includes the end to end tests, the figure of right L to N and figure of eight L to E.
Both figure of eight tests should include readings taken at all points, or as many as realistically practical depending on whether it is IV or periodic testing.
does it trip with nothing plugged in? if it requires a load to make it trip, you may have a N-E reversal at a socket.
edit: it would help if you told us your level of expertise.
No no load applied. I have a socket tester that tells me reversals. But it won't stay on. I have checked all connections and they are correct and tight.
It it did stay on for about 5 hours today (friend put it on) then it tripped and won't go back on!!
I’ll give the OP the same advice I give all Electrical Trainee’s. Employ a qualified electrician to get your arse out of the fire.
The qualified electrician’s fees should come out of your own pocket (not the customers) just to remind you that you can’t learn this trade in a few weeks.
Hope that helps!
Hope that helps!
That doesn't help no!
im ex army don't have the luxury of doing a full apprenticeship due to current commitments. After leaving I did a short course with the army loved it so much I want to do it for a living. So paying out my own pocket I'm studying the 2365 level 2 and 3. I have 17th edition, part P, solar PV design and installation, PAT testing (sitting test in a few days) and my NICEIC test coming up. So yes being experienced and qualified would be nice. But experience comes in time. But as I can't find someone to show me and help me gain the valuable experience. I'm trying on my own. So thank you for your input but advice and guidence is what I'm after not paying someone to do it for me.
I don't think the OP will be back, but if he does:
Are you a trainee or fully qualified? If you are a trainee how come you're doing this work? Daz
Reply to Annoying simple circuit in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
It might be worth asking the customer to turn the oven on 45min before you arrive. then do an IR test on the oven from the isolator with the oven...
