Annoying simple circuit | Page 3 | on ElectriciansForums
Discuss Annoying simple circuit in the UK Electrical Forum area at ElectriciansForums.net
L
Ldm
hi ladies and gents
I have opened a ring final circuit to add 3 sockets. All was goin well till I powered it up and it keeps tripping. I have tested and IR comes back fine. continuity also fine, all test readings are fine. the circuit has 9 sockets and has a 32 type c rcbo. any other info needed please ask.
sorry for the short message but my keyboard is dying.
thank you
I have been replying to people on here but apparently my internet don't want to work.
I am a trainee yes. Domestic installer but training to better myself (currently 2365 level 2 and 3)
all tests did come back as fine and a visual inspection of all sockets shows correct connections. Will start again tomorrow. Thank you to those who helped.
ok well lets move on from here, an r1/r2 will also prove correct polarity as well as contiunity , a 500v insulation test will show any problems with damage cables. So next what were your results.?
Fine thanks mate. I'm struggling to see what Sparkie30's point is, the full series of tests in their correct order will identify any incorrect terminations as we all know. I think some are forgetting that the result of one test is a by product of another :)
I agree fully... also shanky is a bright lad and generally right but i think confused himself here. I also want to know what sparkie30 point is ??
confused? doing R1+R2 end to end tests at ccu wont show up if there in the wrong terminal in field with nothing plugged in
if i was doing r1+r2 in the field then of course it would show up but what most people use a quick R1+R2 for is to check continuity of the ring.
Reply to Annoying simple circuit in the UK Electrical Forum area at ElectriciansForums.net
Very technical :D
It might be worth asking the customer to turn the oven on 45min before you arrive. then do an IR test on the oven from the isolator with the oven...
