Any advice on rewires? | Page 8 | on ElectriciansForums
Discuss Any advice on rewires? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have perhaps done 6 rewires now. They are hard work and I wonder if there are ways to make them easier as I have another 2 much larger ones (3 and 4 storey houses) coming up.
I typically take around 2 weeks for a 3 bed house. This is working flat out (by myself) everyday including one or 2 Saturdays and I feel that is a little longer than most of you would take, or is it about right?
I have just bought the metabo mfe40 wall chaser and hopefully that will speed things up. Are there any tips for using chasers? I'm guessing they just make nice neat notches either side of the chase which you then remove with an SDS chisel? Do you always then use oval conduit which you secure to the wall with the oval conduit holders or is there a quicker way?
Cheers all and hope you are having a relaxing Saturday!
Ps.. I'm awaiting the arrival of the triple blade for the metabo, anyone use it yet? Does it actually take out the middle of the chase well?
pps.. What size conduit do you generally use for 1mm, 2.5mm, 6mm, ring etc etc?
I have just used the triple blade for the first time on hard stone.
I get the feeling it's not really designed for something this hard. It still did it, but it took much longer and the metabo got pretty hot. However, if @brianmoooore is correct then it won't have worn the blade too much. Would be good to have a bit of evidence Brian, as my common sense says the harder the surface the greater the wear.
I have seen it in writing, but have no idea where. More importantly, I've proved it many times over to myself over the last few years, working my way through dozens of 110mm and 230mm diamond discs.
Since retiring from full time electrical contracting and plumbing, I've been extensively renovating my way through the five properties that make up my little 'estate', and have been cutting all sorts of materials. Soft blocks wear the disc faster than ordinary blocks, which wear them faster than sandstones, which in turn wear them faster than granite.
I thought I become one of those fancy youtube electricians for a minute and video myself using the triple blade, so you could see it in action. 😄
Just cant upload it though 😞
It says "the uploaded file was not a video as expected". Ummm, yes it is!
Sussed it! Trimmed it a bit and it works. I love the triple blade!
Ps.. It takes longer than the previous 20 seconds I said. Looks like it's around 45 secs - 1 min for a chase to a light switch. Virtually no debris and a lovely, neat chase. This is into a standard load bearing wall in a house, not sure exactly what material it is I'm cutting into, but it's pretty hard.
pps.. No eye protection 😞
You’re much taller than I had imagined with your head nearly touching the ceiling 😂
The final chapter!
The triple blade has died :(
I let the labourer use It for a rewire. He was getting through the chases very quickly which was great, but I realise now he was pushing the blade too hard.
Rather than let the blade do the work he was forcing it to chew more quickly than it wanted to. In addition, he wasn't keeping the chaser straight all the time. So, pushing it hard plus twisting it a bit caused some of the teeth to bend and some snapped off.
I guess it did its job for a couple of years. It may well have gone on for another few years if used properly.
RIP! I won't be getting another one, as it doesn't really take too long to chisel it out once the metabo has cut the nice sides to it.
I'd spend the money on a replacement triple blade, before going back to twin blades and chisel.
Over here a lot of chasing gets subbed out to companies who specialise in the dirty art of wall chasing, but then we generally need to run deeper tracks as all cables are contained in conduit (mostly round) and the majority of walls are block and floated out in plaster. Dot and dab is very rare and boarded walls are usually a cheap fix to cover old, boss plaster.
It's how it used to be done in the UK, electricians first fix consisted of marking out the route for the conduit and a specialist did the dirty work, this was all before some bright person (did not want to say spark😳) came up with the idea of using ceiling board as it was called, on the walls because it was faster and got rid of a two or three day wet trade, studwork walls cause more problems than they are worth, especially sound insulation and fixings for heavy items.
Have you used the triple blade @nicebutdim ?
I'd be interested to hear from anyone else who has used it and if they like it.
I think you are right and I will probably buy another one. It saved a lot of time over the last 2 years and would certainly have paid for itself
Yes and it was the primary reason for buying this more robust chaser. There are plenty of cheaper options out there which are perfectly capable of powering two discs through a range of materials. I liked the idea of cleaning a chase in one go, with a minimum of fuss.
To my mind the MFE40 and extractor combo would be a lot of money wasted if your intention is to separately chisel out the bulk of material.
I actually make sure I have a spare triple blade on the shelf, I cannot imagine using the machine without it.
With the ad in the middle of your post it says "I actually make" and nothing else, I was unable to see your post in full until I quoted it, THIS IS BECOMING MORE ANNOYING EACH DAY, ADDS IN THE CONTENT OF A POST WHATEVER NEXT, ARE YOU LISTENING ADMIN?
  • [ElectriciansForums.net] Any advice on rewires?
Completely agree Mike. the ads are now in the posts, actually blocking the content from view. They only ever get worse.
Reply to Any advice on rewires? in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
