Any tips on lifting glued down chipboard? | Page 3 | on ElectriciansForums
Discuss Any tips on lifting glued down chipboard? in the UK Electrical Forum area at ElectriciansForums.net
Warrington
So. Having brought a new house the misses now wants downlights. Not an issue. Only snag is the boards aren't screwed they are glued down. I've done a few new builds but everything is wired from below so how is the best way to lift the boards? Is it just a case of expect to replace what you have to lift? Will it come up at all? Will I spend weeks scraping glue off the joists?
Serious section now, as its a new build see if you can get hold of the architectural plans as then you will know where the joists are and the noggins so then can plan the cable run, when I did my flat rebuild we where lucky to have enough room to lay a false ceiling with plenty of space to run any additional cables if required.
I will add my vote to the board cutter
It's neat, quick, and can be used over and over on all sorts of jobs.
Try to avoid lifting the floor, for all the reasons already stated.
My wife wanted downlighters in the kitchen too...the bedroom above had a fitted wardrobe at one end, so I lifted the floorboards in there and BINGO the joists ran lengthways so it was an easy task to pull the supply into that space, and feed cable to the downlighter holes drilled in the kitchen ceiling, without having to disturb any of the bedroom floor itself. Replaced the boards in the wardrobe, bit of spare carpet on top, job done.
If the joists run the wrong way, then the board cutter, routabout is your friend.
Reply to Any tips on lifting glued down chipboard? in the UK Electrical Forum area at ElectriciansForums.net
