Hi I dunno if you could help me with this; i bought a sony home theatre sound system amp in US and need use in UK, it's 120v, 60HZ, what can i do in particuler to change the 60Hz to 50HZ, is it poss, i know i have to figure the voltage output to get a rating for suitable transformer, this is where my brain stops working, cheersthe trip setting on our gfci outlets is 5mA designed to be below the lethal shock level. Us Yanks dont see the advantage of a trip level of 30 or 300mA which would allow a lethal shock without tripping.
The new thing here is AFCI [arc fault circuit interrupters] designed to prevent fires due to sparking.
BTW, im from California, but have been working in the Mid East for 3 years where im learning 17th ed. The difficultest part is the terminology is different for every little thing.
cheers, but not quite sure how to hook up, can u expand a bit, might be my way thru, thxon second thought, all electronics are low voltage DC internally after the AC to DC transformer. so if possible, hook a DC power source into the internals of that system, attaching it after the transformer. 3v DC is typical. IMHO. YMMV ["your mileage may vary" as we say in the states]
I think I'm getting the jist of wat your saying, but checkin abvout using a transformer, it seems that if I used a 750w (output max 700w) I woudn't have to be to bothered about the freq, I think that's wat u were intemating in your point, but would that be a safe solution e.g does it damage the machine, I undersand freq fluctuates anyway and most of the AV unit use is AC and not so much DC, wat do u thinkon second thought, all electronics are low voltage DC internally after the AC to DC transformer. so if possible, hook a DC power source into the internals of that system, attaching it after the transformer. 3v DC is typical. IMHO. YMMV ["your mileage may vary" as we say in the states]
my experience is most electronics is DC internally, am i wrong???I think I'm getting the jist of wat your saying, but checkin abvout using a transformer, it seems that if I used a 750w (output max 700w) I woudn't have to be to bothered about the freq, I think that's wat u were intemating in your point, but would that be a safe solution e.g does it damage the machine, I undersand freq fluctuates anyway and most of the AV unit use is AC and not so much DC, wat do u think
when u take apart the system, you will find a small transformer attached to the cord where [in a system bought in the states] 120v goes in. in other words, its a 120 VAC to
[typically] 3 VDC transformer. Its two ouputs are 3 VDC and ground. If you have one,
you can replace it with a 230 VAC to [typically] 3 VDC transformer and replace the wall cord [american plug] with a Brit or euro plug.
Ok I checked out with a couple of electricians lets say more estute than me, and low and behold, as they have never worked on US type of equipmemt before there quite apprehensive touching this, even after I explained what your solutions were; i have another person to speak with, but in the event, iv'e come up with plan B, that iswhen u take apart the system, you will find a small transformer attached to the cord where [in a system bought in the states] 120v goes in. in other words, its a 120 VAC to
cheers for getting back on this..blinding stuff, one thing my voltage is 250W, not 700W as I thought, so i got a 500W voltage convertor...maybe on to the right thing afterall, cheersi agree, the step down transformer is a good solution, and you are correct that
the internals of your system will only see DC anyway, so 50 or 60 hz in the wall voltage is irrellevant. good solution![]()
Reply to the thread, titled "Anyone have American electric questions?" which is posted in USA Electrical Forum on Electricians Forums.
