Well, doesnt 17th ed require you to de-rate the ampacity of the wires used if there is more than 3 current carrying conductors? In the NEC if you have - for ex. - 10 wires in a raceway [conduit or trunking] the ampacity of the wires is de-rated 50%.After having just come back from my holiday in florida, a couple of things i wondered if you could help me with .
1. I have noticed that you do not seem to use anything but conduit for commercial installations, the only time i saw trunking used was in disney with lights on it and in small pieces below panels top common up conduit runs. Has nobody thought of introducing trunking to the states as it would seem to be a much quicker way of doing things. instead of 20 runs of tubing you could have one run of trunking???
single pole switch $1 or $2, two way switch $5-8 each.2. Why dont they like putting 2 way switching systems in hotels/villas, the amount of times i switched the bedroom lamp on at the door switch then off at the lamp and then come the next night go to turn it on and its not going to come on as its off at the Lamp. Stumble across the room to find the lamp and turn it on there. Then repeat every night till I leave .
Nick
Reply to the thread, titled "Anyone have American electric questions?" which is posted in USA Electrical Forum on Electricians Forums.
