Approved tradesmen scheme | Page 5 | on ElectriciansForums
Discuss Approved tradesmen scheme in the UK Electrical Forum area at ElectriciansForums.net
Redditch
Hi, as I’m trying to grow my little business I keep coming across many obstacles namely trying to join a competent trade scheme. NAPIT seem to be the only one that suit my current situation.. has anyone any experience with these people as I’m finding it difficult to say the least! Or can anyone recommend an alternative. I don’t have my testing and inspecting ticket which rules my out of NICEIC!! 😭 I need something in place to get my work notified to council
It is a law of the land that many domestic installations, of all kind, should be notified. If an electrician, for example, wants to bypass said law, it is up to them. If danger and problems result, let them take the consequences.......but if someone dies as a result, could they care a tinkers about conscience and taking blame?
Again for some reason we're equating not telling someone you've done work with potential danger. Why? Why would 'danger and problems result' from not notifying?
That link has been made numerous times by others defending the notion of non compliance with building regulations. As such it is quite reasonable to respond to the argument.
Even the British Standards are not rules, but advisory, they may well be used in court as a reference, but if proof can be given that the work was over and above the standard then that would be taken into account and any case based on the BS would be void, the HSE are not in the business of bringing case's to court that they don't think they can win, in the case of a death however, that would be a criminal proceeding and not brought by the HSE even if they where asked for comment as they may well have been called to the scene of the accident/failure.
Rules /law /guidelines. Amazing how millions didnt know the difference during covid !
Someone who has such a blasé attitude to complying with the statutory requirement to notify, is likely to carry over that attitude to other aspects of their work. Such as the requirements for earthing the armour of an armoured cable.
There may be some truth in this, although I think it's more likely to be the other way round - someone who carries out sloppy work is less likely to go to the effort of notifying the job. That said, I (and probably most of us here) have seen work where about the only thing that was done right was the notification.
It won't.
There was an earlier post suggesting that all of the dangerous work out there never had any consequences.
This is the post I'm referring to:
Pehaps I'm misread ipf's post, but I too am struggling to see how not notifying a job would result in death.
It reads bad, yes. My fault, late.
Maybe As a result of things in general not being done correctly.
or 'If danger and problems result, due to bad workmanship,
Danger would not result from non notification but notifying is, to some extent, a method of taking responsibility for the job as a whole.
It is only part P, after all :)
I'll agree, the system is a mess, but it's not going to improve the situation if sparks, be they PP registered or not, just ignore it.
It would though. If every spark said 'No, this is stupid and i'm not doing it. Let's see you police it, LOL.' they would HAVE to put sensible rules in place. You know like letting qualified men actually install basic circuits in houses without having to pay for it. The qualifications mean nothing if you can't use them to carry out the actual work they relate to.
IMO the qualifications should be 18th, NVQ, AM2, and full testing and inspection. Once you have those you should be able to touch any install you like without having to pay because passing them proves you know how to do electrics safely. The only thing i would change about this is i would make the 18th test an actual test of your knowledge on the regs and not just a 'can you find it in the book' exercise. It should imo be rolled into the inspection and testing qualification as they sort of go hand in hand.
If this isn't good enough, then instead of introducing stupid rules like schemes they should simply make the qualifications more in depth and harder to achieve.
Some of those suggestions are great, but at odds with the fact that on many occasions you've told people not to bother with qualifications and to crack on regardless.
Reply to Approved tradesmen scheme in the UK Electrical Forum area at ElectriciansForums.net
