L
Lazlo
or have you begun to install metal re:amendment 3...
Discuss Are you still fitting plastic CUs...... in the UK Electrical Forum area at ElectriciansForums.net
Had two British Standard RCBO's fail on me this week, one went bang in my face then unsurprisingly failed to work the other just failed to energise the circuit altogether. Think I now know what BS stands for. The quality of these components is poor. I'm thinking the one that went bang could have started a fire in some instances. When I returned the second one the guy said he'd had four back in total. Dodgy batch, who checks this stuff??
I have no doubt there are people working that do not have the correct skills and/or education and I've seen plenty of burnt ends in DBs but I do think there is a lot of rubbish being manufactured and this may also play a part in the whole Keith Flint Distribution Board saga. More stringent training and better designed/manufactured gear.....in an ideal world.
Right I'm off to buy a 8mm thick cast iron DB which contains MCBs you can get in a cracker at christmas.
What make?? Do you have the batch number?
There seems to be a large number against this new regulation..
Does anybody have any figures as to the number of objections prior to its introduction?
Pethaps it should have never been introduced and also why don't we start a petition to get it scrapped
Part P qualification?a Part P qualified competent person is be required to install and /or sign-off the installation
The relevent part of the AMD 3 draft that went out to public comment is as below....
421.1.5 Where electrical equipment in a single location contains flammable liquid in significant quantity,
adequate precautions shall be taken to
421.1.200 Switchgear assemblies including consumer units shall:
(i) have their enclosure manufactured from non-combustible or not readily combustible material, or
(ii) be enclosed in a cabinet or enclosure constructed of non-combustible or not readily combustible material.
NOTE 1:NOTE 2
Where no product standard exists, the materials of an enclosure shall withstand the highest temperature likely to beproduced by the electrical equipment in normal use
Ferrous metal e.g. steel is deemed to be an example of a non-combustible material
For the purposes of this regulation insulating material e.g. plastic meeting a 960 oC glow-wire flammability test as defined in BS EN 60695-2-11 is considered to be an example of a not readily combustible material.
Materials used for the construction of enclosures of electrical equipment shall comply with the resistance to heat and fire requirements in an appropriate product standard.
Standards are (or should be) written by industry by consensus where consensus isdefined as:
‘General agreement, characterized by the absence of sustained opposition or substantial opposition by any important part of the concerned interests andby a process that involves seeking to take into account the views of all partiesconcerned and to reconcile any conflicting arguments.’
The new amandment is not the same as what went out to public comment and it also doesn't seem to take into account our views and opinions on the matter..
There seems to be no documents available with regard to the general consensus from the DPC.
I myself will not be fitting metal consumer units unless it is to meet certain criteria based on its environment.
C,
Thanks for this ... I have not personally followed the whole debacle from its inception ... just got involved with the debate after the 'empty stable' was found! It is useful to see another of the steps on the road to the current situation and to surmise as to the parties who produced this draft for comment and those who influenced its final text. Unfortunately 'design by committee' rarely produces a beautiful beast unless there is a strong commonly held vision of the required result and common motivation to achieve that end. Furthermore, unless a holistic view is taken of cause and effect, it is unlikely that treating the symptoms of the disease will cure its root!
Reply to Are you still fitting plastic CUs...... in the UK Electrical Forum area at ElectriciansForums.net
