L
lammy76
Hi guys /girls can you run armoured cable straight into c/unit or does it have to go into Henley block and then run tails from that ?
Discuss Armoured cable in the UK Electrical Forum area at ElectriciansForums.net
As I said to people on her earlier spark run the swa to Henley box and then run meter tails of this and used the grey as Cpc
Will a stuffing gland do or does it have to be some sort of fancy special one?
go away...Hi guys /girls can you run armoured cable straight into c/unit or does it have to go into Henley block and then run tails from that ?
What were you taught would be the correct way or are you a D|IYer?Ok everyone has plenty to say but no one has said the correct way
If you were familiar with henleys you would know that it's impossible, terminating them directly into a CU is a better way but it's easy to get wrong.Ok everyone has plenty to say but no one has said the correct way
Best advice so far.go away...
Just a gromit trev
There is no way in hell that you can correctly terminate an armoured cable into henleys mate. Not a chance
You can split tails into a henley block that is correct lammy
Can't get just a Gromit - it has to come with a Wallace.
Reply to Armoured cable in the UK Electrical Forum area at ElectriciansForums.net
