Assessment / Install questions | Page 2 | on ElectriciansForums
Discuss Assessment / Install questions in the UK Electrical Forum area at ElectriciansForums.net
M
Mat-sparks
Hi All,
I soon have my Assessment with Elecsa (1st one) a friend of mine needs some work doing so am going to take advantage of this and use it as my Major works...
I have a couple of questions though.. (as I am obviously nervous and worried about covering everything correctly)
My friend needs his new hot tub wiring up...
Hot tub requires (according to rating plate) a 230-240v 16a class c breaker. This is fine, I understand this.
My problem comes in the form of my friends CU being obsolete, so obtaining MCB's for it is a pain anyway let alone finding a Class C.
So The options are, Complete consumer unit change - Friend not so keen on this, which is understandable
Try my luck with a B type which I can get 2nd hand (assessor may not like this if he notices the rating plate says a C)
I could (and this is what I will probably do, subject to peoples opinions) fit a 32a type B to the spare way in the CU, then run 4mm T&E to a small garage style consumer unit which I will locate next to the original CU and in this fit a 16a type C. Then from this run 2.5mm armoured down to Garden and straight into rotary isolator that is supplied with Hot tub.
Or am open to suggestions.
Cheers
Reply to Assessment / Install questions in the UK Electrical Forum area at ElectriciansForums.net
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
