Sparky83
....Pratt!
I was having a disscusion with a mate of mine and radials (like you do)
and we disagreed on on feeding a 2.5mm t&e from the 32a mcb of a ring ciruit.
I thought that you could only spur off the ring from a point on the ring itself like a socket, but he said you could take it straight from the mcb itself. To me this then becomes a radial circuit sharing a mcb with a ring main?
What would happen if the ring was removed and the radial circuit left, on a 32amp breaker, that would be right, so what makes it ok when a ring shares the mcb?
I've had a look about and even on this forum but some say its ok some dont. Im happy to admit im wrong, which is how it would seem it is but i would like a good explenation as to why its ok.
Cheers
Shawn
Cheers
Shawn
