BAFFLING smoke alarm problem | on ElectriciansForums
Discuss BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SeanSparky
Hi, I'm absolutely baffled by this and wondering if anyone can see an answer or have ever came across this problem.
Basically I have a smoke and heat detector interlinked, nothing fancy.
Feed is from the light closest to it.
T&E feed-3 core interlink.
When both smoke heads are on, the light turns on and in the off position it just dims down, doesn't go off.
Take 1 head off and the light works fine, doesn't matter which head you remove.
The T&E feed is 100% a perminent feed.
Please please somebody explain this for me because I'm baffled
sounds weird to me have the smoke detectors got lights inbuilt into them??
all i can think is have you connected the smoke detectors wrong at the lights ? have you picked up a switched live ? or maybe you wired them in series ? Have you confirmed you definitely have Live and a Neutral supply rot the smoke detector ??
pictures will help
This is all I have added, from the junction box onwards. Lights work completely fine with only 1 heat or smoke, doesn't matter which one i disconnect.
[ElectriciansForums.net] BAFFLING smoke alarm problem
Wots the connections in the box marked 'X'? Are you sure you haven't mixed up your, lives, switch lives and neutral?, i.e. neutral as live (or switch live) and live as neutral
That's the standard pendant light, Swithed live, N, and loop,
I've jumped off the loop, N and earth
If all else fails, I recall a thing about smoke and heat not always compatible for interlinking (hopefully not imagined) - perhaps try removing interlink to heat and see if it changes behaviour?
I pretty much have done, but also the detector bases have just got a connector block for the T&E/3core. You then have a short lead to connect into the connector blocks and the other end has a little plug in connector to plug into the detectors, and with the detectors unplugged the light works fine, so that should mean the hard wiring is fine doesnt it ?
Even works with just 1 detector plugged in so my best guess is it's something to do with the 3core, most likely the interlink core ??
Disconnect the lot and reconnect double checking all connections.
So no dead tests then....
Reply to BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
