BAFFLING smoke alarm problem | Page 3 | on ElectriciansForums
Discuss BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Anyhow's, its not working and you need to back to basics. Incidentally, why is a plumber doing someone else's electrics?
I don't know but I once wired a 2way and fitted LED lamps that wouldn't go off completely and changed the lamps to another make and all was fine I have also heard of cables run together getting enough power in them to make an energy saver glow ! The folk were convinced they had a ghost maybe it was so unless it's something like that or to do with your battery's in your alarms but like you said better not to guess but not being able to see it makes it harder to picture things. Just trying to think out of the box as your convinced your wiring is right !
But the same would happen with only 1 detector connected, but it only happens when both are connected
Not necessarily, as it's a compact fluorescent lamp it is not a simple resistive load. It will need a minimum voltage across it to illuminate.
With two alarms connected you have half of the resistance in series with the lamp
That is caused by capacitive coupling between conductors.
Reply to BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
