BAFFLING smoke alarm problem | Page 5 | on ElectriciansForums
Discuss BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
think he's drawn a smokescreen over the problem now.
How will that cause the light to partially illuminate when the switch is off?
possibly that the light is seeing the smoke/s internal resistance as a path for sufficient current to make it glow ( as a parallel path to the switch)
That was in reply to the post suggesting that the neutral and smoke interlink were switched.
As far as I can see that would only result in possibly blowing up the smoke head
Reply to BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
