BAFFLING smoke alarm problem | Page 2 | on ElectriciansForums
Discuss BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
what have you done so far to try and identify the problem? What tests have you carried out and what were the results?
In my opinion the symptoms suggest a series connection of loads when they should be in parallel, so would probably measure the potential across each load and at each point wrt earth.
This has crossed my mind also but I'm assuming All BRK brand detectors should be able to interlink
Can't find anything online
If all else fails, I recall a thing about smoke and heat not always compatible for interlinking (hopefully not imagined) - perhaps try removing interlink to heat and see if it changes behaviour?
That's the standard pendant light, Swithed live, N, and loop,
I've jumped off the loop, N and earth
If the 'standard pendant' has been connected & wired by someone else, are you sure that has been correctly wired up? If not, and the sw L, lives, and neutrals have been mixed up, adding the loads (smokes), could present voltage at the neutral of the light when its switched on.
Edit; previously incorrectly wired/connected pendant, would still illuminate when switched on, even though incorrectly connected.
If the only thing that has changed is the addition of the smoke alarms then the only way I can see that they would cause this operation is if they are connected in parallel with the switch, and therefore in series with the light.
When the switch is closed the smoke alarms will be shorted out and when the switch is open they will be in series with the light.
I've checked it, everything is correct
But the same would happen with only 1 detector connected, but it only happens when both are connected
Reply to BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
