Bathroom zones with a ceiling shower head | Page 2 | on ElectriciansForums
Discuss Bathroom zones with a ceiling shower head in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Some fixed current-using equipment including ventilation and luminaires is allowed in zone 1 but must be IPX4, IPX5 if exposed to water jets.
No restriction in zone 2 but must be suitable for the environment - see manufacturers' instructions.
This work will still be notifiable after the changes.
Am I reading it wrong then?
I'm reading notifiable as:
- Installation of a new circuit
- replacement CU
- Work in a special location - redefined as effectively bathroom Zone 1
- Swimming pools
So no kitchens, outside sockets or bathrooms in Zone 2 & outside
Well, for what its worth I'm VERY interested to see what the schemes say/define these changes as .......so over to them and lets hope they get their fingers out well before the 6th April '13
Why are we even chewing the cud here? IP999 to prevent morons frying themselves whilst furkeling about in a paddle shower stuck to the ceiling with blue tak and a bit of good luck. Regardless of what the literature in the big orange shed says, that shower has the potential of directly spraying water on anything in or on the ceiling so yes, your common sense probably is lacking and in this case the regulations have nothing to do with common sense, they're actually very clear, you only need one tall geezer using it to steady himself after a skinfull whilst cleaning his bits and the jets hit the lights. Work the rest out from the regs or get an electrician in. I'm also out.
So do you think the schemes will make all the registered competent persons registered third-party certifiers? Or are non Part P competent person installers going to find there aren't any third-party certifiers about?
- replacement CU
- Swimming pools
no , that sounds about right on the part p changes.
Even if I were a scam member there is no way on earth I'd be putting my name on any install that was not done by me.
Didnt bother reading so Shower is on ceiling defo class as zone 1, you are getting wet are you not, bgb is a guide not a law as there are so many changes and this proves a change, so stick with idea im getting wet you will be fine zone 1 think your in zone 2 your strange, and breaking law as you will be in jail if it hurts LMAO.....
Reply to Bathroom zones with a ceiling shower head in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
ok cheers for the help lads
I thought that too, but I didn’t want to upset the old fella by telling him 😛
